Old 10-13-2014, 05:02 PM
Karbonkid Karbonkid is offline
Default Will a plane fly faster at specific RPM leaned / full rich?
ok, not sure why I am second guessing myself on this but figure there are many with answers here.
When you fly at 2400 RPM full rich will you fly slower than you will at 2400 leaned for max power?
some reason I feel there is more to this than 2400 puts x ammt of power to the air which makes y speed.... but I may be off
Old 10-13-2014, 05:11 PM
jrs14855 jrs14855 is offline
Default Leaning
Fuel injection will definitely gain a couple knots at best power. Carb depends on the individual setup. A pressure carb has no significant change at low altitude. Float carb depends on the individual setup. Most POH's call for leaning for takeoff above 4-5000', again this may not hold true for some unique installations.
Old 10-13-2014, 05:13 PM
RV7A Flyer's Avatar
It's not called "Best Power" for no reason
Old 10-13-2014, 05:23 PM
rjbob rjbob is offline
2,400 RPM...fixed pitch prop...same speed no matter what the mixture (all else being equal).
2,400 RPM...constant speed prop...more power=more speed. If leaning gets you more power, speed will increase because the propeller pitch will increase. (all else being equal).
Bob Edison
RV-7 N749ER...(GO NINERS)
ATP CFI-II-ME
Anchorage, Alaska
Let me know if you're RVing to Anchorage!
Old 10-13-2014, 05:45 PM
RV6_flyer's Avatar
At 2,300 RPM, I can see 10 KIAS, 10 Kts Ground Speed change with only a mixture change. The mixture change cost me 1.5 GPH fuel flow for the extra fuel burn to get 10 Knots.
Best Power mixture or Best Economy mixture is what I typically run.
Full Rich and Max Power can be the same thing at standard sea level but at altitude, Full Rich may be less power than Max Power mixture setting. The answer to your question depends on altitude.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 10-13-2014, 05:53 PM
rzbill's Avatar
rzbill rzbill is offline
If you lean towards best power in the climb, you can see the climb rate go up. Watch CHT of course.
Bill Pendergrass
ME/AE '82
Old 10-13-2014, 06:04 PM
N941WR's Avatar
N941WR N941WR is offline
With a FP prop, starting at 2400 RPM, the RPM's will increase as the plane accelerates with leaning because you are producing more power.
Full rich is too rich, thus you are not optimizing your fuel to air ratio for maximum power. Leaning it to the proper stoichiometric mixture ratio produces the best power. However, depending on your CHT's you might want to run it a little rich to keep your temps down.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-13-2014, 06:31 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Study this graph, the answers are all there including many to questions you have not asked.
(Courtesy Advanced Pilot Seminars)
At around 75dF ROP is where the "peak power" is found, and while you can fly there for periods of time at high power settings, without destroying or causing significant harm that is not what the maker intended. And hence you have a mixture knob.
If you want to get the most out of your engine while maintaining stress levels on the engine (induced from Internal Cylinder Pressure ICP) then use the appropriate amount either LOP or ROP as your mission requires.
Take a look here at this interactive. http://www.advancedpilot.com/redbox.html
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 10-13-2014, 07:12 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Agree totally.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-13-2014, 08:19 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Agree totally.
Then why, while testing a new FP prop, did I get max speed out of leaning for max RPM?
