Old 10-19-2006, 06:36 PM
RScott RScott is offline
Default Ta Da! Smoothing radii in notches
Smoothing edges in notches has been a tedious activity. I just haven't been satisfied with getting into those radii with a small file, sandpaper, etc. And having many years experience finding cracks in places just like that on F15's, I am not about to let those edges go unfinished.
Finally, the easy way for the radii: The side of a drill bit. Chuck it in the drill, spin it in the little radius for 2 seconds and it's done! The bit I use is just small enough to fit into the radius at the bottom of the cutout. I tried a reamer, but for a radius at the corner, the reamer wanted to skip out of the notch and skitter across the surface. Can be a problem with a bit also, but less so. Does not leave the polished surface you get with a Scotchbrite wheel, but it does convert those marks that lie across the edge to harmless marks going along the edge.
Now, let's find an easy way to do the edges of those notches!
Old 10-20-2006, 08:05 AM
TerryWighs TerryWighs is offline
In a pinch...I like using a very small round file (the size used for sharpening my chain saw)...only takes a few controlled strokes. I then follow that with tightly wrapping some wet/dry sandpaper (400 grit) around the the shaft and smoothing to a polish finish on the edges. Seems like everytime I use something with power...things get a little exciting....
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
