Go Back   VAF Forums > Model Specific > RV-14
  #21
Old 11-08-2018, 09:06 AM
Jimd Jimd is offline
Default Edit-
I had an offset cup set and I had already ground for another issue so I prepared that for this task, but. I ended up removing the retainer spring from the 3X gun and used a mushroom set WHITHOUT a rubber guard so I could get as close to the flap bracket. This worked okay, not ideal but good enough. I would want just a bit better or easier method if this were on top.
Jim
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
Old 11-08-2018, 08:53 PM
VD919 VD919 is offline
Default That?s cool
Is it me but Emerit?s technique looked good but the fact he got to build inside the house is more amazing to me.
Vin
RV14 Planning Phase
Pd Dues 2018
Old 11-09-2018, 08:10 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Same problem on the RV-10 and RV-14. This is what I did and recommend:
- Take a 1/2” x 1” or so piece of .125 aluminum, run the edges over your scotchbrite wheel.
- Drill a #30 hole biased to one side. Use your deburring tool to make a small countersink on one side. Insert a just slight linger round head rivet and set so that the shop head is flush with the back side of the aluminum. Buff smooth.
- Add clear packing tape on the back side.
- Tape your now finished custom rivet tool over the rivet you want to set. Have the round head right over it.
- Use your long round head rivet set and drive the rivet.
- Repeat as needed.
Carl
Old 11-09-2018, 08:19 AM
Yank Yank is offline
Don’t throw away that custom rivet tool. I’ll rent it from you for a six pack of Sierra Nevada......
Dogwood Airpark, VA
RV-14 Tail kit in progress
Old 11-10-2018, 09:31 AM
Moeggeploeg Moeggeploeg is offline
- Take a 1/2? x 1? or so piece of .125 aluminum, run the edges over your scotchbrite wheel.
- Repeat as needed.
Carl
Now that is out of the box thinking!
Old 11-11-2018, 07:47 AM
77bonanza 77bonanza is offline
- Repeat as needed.
Carl
Carl, I am having a hard time visualizing the above. Do you have a photo you can share re the above.
Thanks.
Old 11-11-2018, 08:27 AM
tyconnell's Avatar
tyconnell tyconnell is offline
Thanks.
Ditto, would love to understand this. +1
Ty Connell
ty.connell@gmail.com
Donated 2020
Old 11-11-2018, 09:15 AM
Thanks.
On the road but will take photos of making one. Think really simple and you will be there.
Carl
Old 11-11-2018, 10:00 AM
kbalch's Avatar
kbalch kbalch is offline
- Repeat as needed.
That is absolutely brilliant! Wish I'd thought of it before doing my bottom wing skins. Mine came out OK (they'll look fine under paint!), but undoubtedly not as nice as yours. Great idea!
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
Old 11-11-2018, 10:01 PM
Default Riviting Bottom Skin
Carl
Carl, thanks. I am trying to visualize your tool but I must be looking the wrong way. Having a photo will help me understand how you make the tool. Can you take photos of the tool's top, bottom and other if needed? This is my first build and I struggle to visualize properly!
Thanks.
