10-07-2014, 04:50 PM
Gascolator info ?
Van's catalog lists 2 gascolators, (Vans and Andair) the Andair is rated at 1000psi
no rating on the Vans. Question, is the Vans gascolator suitable for use on a FI engine 25 to 30 psi? I asked Vans, no help, theres did not have a rating?
The aircraft, equipped, with an YIO-390-EXP engine, presently has no gascolator, one is required if the aircraft is to be imported to Canada.
Dick
10-07-2014, 05:09 PM
I would not put a gascolator on a fuel injected engine. Just asking for vapor-lock and it is not needed anyway.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
10-07-2014, 06:21 PM
Every engine in Canada has one, I never hear of problems due to a gascolator. Mine is mounted on the firewall low on the right side in the engine compartment. I have an iO-360 C1E6. the finger screen in your fuel servo is extremely fine, I want anything in the system stopped before it gets that far, and the gascolator does that job well.
10-08-2014, 03:55 AM
Gary,
What gascolator are you using? I am concerned that the Vans unit might not be up to the higher pressure of the FI engine.
10-08-2014, 01:41 PM
I have a slightly used Andair gascolator if you need it.
Nigel
RV9A-N113SQ
52F
10-08-2014, 04:29 PM
Originally Posted by N661DJ
Gary,
I am using the vans gascolator.
10-08-2014, 04:49 PM
The Andair gascolator can serve as a prefilter for the electric fuel pump, thereby replacing a discrete fuel filter. Mounting it inside keeps it cooler.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
10-08-2014, 07:29 PM
I have been using a Van's gascolator on my IO360 for about 150 hrs with no problem.It's mounted low on the front of the firewall, and I have it shrouded to help keep it cool.
Idle is a bit lumpy when the engine is hot, but acceptable with the electric pump on.
I'd prefer not to have one but I live in Canada.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
10-08-2014, 11:42 PM
WTB Andair Gascolator
If anyone has a new Andair in a box I'd like to buy it.
RHill
