06-01-2015, 09:45 AM
Red Cube?downstream
Thanks Tom. I was looking at putting it between the pump and servo, but I soon saw that those hoses are BIG?hence my question about SIZES and lengths. Putting it between the servo and spider looks like it eliminates any need for reducers/adapters, so that's what I'll do. I'll get back with you about hoses after I look at exact location, per your suggestion.
Do you have any pro/con advise about allowing the cube to float, vs. mounted on FW?
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2020 Dues contributed
12-07-2015, 08:50 PM
Has this been decided?
I just spent the last hour reading about 50 posts - all with a different opinion on where and how to mount the Red Cube. What is confusing is the different locations for FI and carbs. I have a carb and there are more locations discussed for carb engines than FI
Im about ready to throw it away and just use a stick to know my fuel use!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
12-08-2015, 03:41 PM
I was in the same quandary at that stage. Then I happened upon a builder's website (it may have been Randy Lervold's) that showed the Cube in a place that would work perfectly for me. I put it there - between two hoses in the line between the servo and spider - and it has worked great ever since.
I recommend you put it in a place you can access readily ... Red Cubes fail every now and then. My first one had defective threads and had to be replaced at 12hrs flying time.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
12-08-2015, 09:22 PM
Thanks Terry. I spoke with Tom and he said to mount it and then tell him what length hose I need and he will make them for me. I told him to quit milking his knee - near death experience and get back to work!
rockwoodrv9a
Williamston MI
O-320 D2A
12-09-2015, 07:45 AM
Here's where I put my Red Cube on my -8.
Awaiting new hose from Tom to run between Cube and spider.
Warning: untested. Still building.
Bruce Windom
QB RV-8 N148BW
Reason: Added sentence
12-09-2015, 12:19 PM
Your chosen location is going to be the high point of the installation. Just what EI's installation guidelines say to avoid.
12-09-2015, 07:23 PM
As the op I thought I would share where the cube ended up.
Tom made a short hose with a 45 on one end to go to the servo (rear outlet), keeping the cube as low as possible.
Jared Waite
RV9-A Flying
Superior IO-320
Catto 3 Blade
12-09-2015, 09:48 PM
Perfect!
Jared, Thanks for the picture. That is exactly what I am going to do. Im even going to paint it white as a tribute to you! Ha!
rockwoodrv9a
Williamston MI
O-320 D2A
12-10-2015, 06:50 AM
Actually, it's still uphill to the spider from there, per my installation instructions. I Googled for more info, and it looks like there are "old" Red Cubes, and "New & Improved" Red Cubes. I found a 25+ page set of installation instructions on line that I think pertain to the older model. My Red Cube came with a 2 page install sheet, that says: "…the fuel line on the outlet port should not drop down after exiting the transducer."
Pretty sure I complied with that, but will double check…especially in a level flight attitude.
There was no mention of bubble-trapping loops in my installation, but I DID see references to that in what I think was the "old" manual.
Thanks for keeping me honest. Love the feedback on this site.
Bruce Windom
QB RV-8 N148BW
Reason: added explanation.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
