Old 10-06-2014, 03:09 PM
walkman's Avatar
walkman walkman is offline
Default Where can I find this inverted oil sump fitting?
This got damaged in removal or shipping.
Aviat wants $280 for basically a -10 AN Tee with a strainer glued into it.
Does anybody have one or know of a reasonable source?
https://www.dropbox.com/s/tfv3k6irb7...tting.JPG?dl=0
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 10-06-2014, 03:24 PM
jthocker's Avatar
jthocker jthocker is offline
Raven aircraft
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 10-16-2014, 03:24 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
If the strainer is in good shape, I would just order the AN parts from Spruce and remove it from the old "T" and glue it in the new "T".
Jerry Esquenazi
RV-8
N84JE
Old 11-25-2014, 06:47 AM
Boyd Birchler Boyd Birchler is offline
Default Inverted oil sump fitting
The strainer is going to be difficult to remove from the old AN10. We have fabricated one out of the appropriate sized aluminum tubing and glued it in the AN -10 fitting with epoxy (slow setting JB weld). We cut the openings out with a wiz wheel on a die grinder and welded a little round cap on the end. It essentially looked the same as the Christen fitting when we were finished.
