Plane Power Alternator problems RV-7
60 amp Alternator and Kit w/OV protection
Part Number = ES ALTERNATOR DELUXE
I have just replaced my alternator with the above Plane Power Alternator supplied by Vans (ES Alternator deluxe).
It has been connected correctly with the white wire going to the indicator bulb and from the bulb to the dc positive bus. The red wire goes to the 5 Amp circuit breaker then to the dc positive bus. The alternator switch was selected on for engine start and remained on until engine shutdown.
Before start the indicator light is on steady.
After start up it behaved perfectly, the light goes out and charges as it should. The loads were put on, Radio, landing lights etc. After about 3 or 4 minutes the alternator warning light flashes on an intermittent basis, maybe at a frequency of about 1 second. Voltage indicates 14.4V but flicks in sympathy to the flashing light.
Any idea?s chaps
