Old 10-03-2014, 06:10 PM
Guilhermepilot's Avatar
Guilhermepilot Guilhermepilot is offline
Default Eletrical pump install question
Seems like heve a new model airflow pump bought from vans and my dyagram is related to old one, for what I could see there is no return line on this new one,
somebody there to help me ?
Guilherme Plassmann (Brazil)
RV7A (Mr Flame) slow kit S/N 74285 Finished 04/14/15😀😀😀😀flying
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
LR30,PRM1,C560,C510S,HS125,B350 FAA/ANAC Pilot
Donation made 2016
Old 10-05-2014, 10:26 PM
Dune Dune is offline
That is correct. The new design does not require a return line. The return is built into the fitiing that comes attached to the pump.
It will also require either a modification to the housing that Van's supplies which was designed for the previous model pump or a somewhat creative routing of the tubing.
Old 10-06-2014, 10:27 AM
many thanks
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
Old 10-06-2014, 11:28 AM
Also If anyone has a pic of this new set up
Would be very welcome
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
Old 10-12-2014, 10:58 AM
Your timing is good...mine just arrived. Van's is in the process of designing a new attach bracket, but I decided to get the pump right away and will fab my own bracket.
Doug
RV-9A "slider"--sold in July 2021
Donation made for 2021
Old 10-13-2014, 11:09 AM
I'd be curious to see mounting solutions for this too, if anyone has pics.
Doug
Old 10-13-2014, 11:31 AM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
Default My installation
here are some pictures of my installation. No modification of VANS cover required. I am not flying yet but I have had everything hooked up with no issues.
Tom from TS flight lines made the fuel lines. Tom is awesome and highly recommended.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
Carbon Cub EX2 N852AZ KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 10-13-2014, 12:10 PM
Very slick install, Jeremy. Thanks!
Doug
Old 10-13-2014, 02:19 PM
I was told that is no return line, so that the way mine is
http://i1349.photobucket.com/albums/...psmv8hdndn.jpg
http://i1349.photobucket.com/albums/...psvqzrfyxm.jpg
http://i1349.photobucket.com/albums/...psprtuxeau.jpg
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
