I had the same problem and re-bent mine. Problem is, while I got it to fit OK, it doesn't look good. I decided to not worry about it, and it is one of those things you don't notice once you are further down the road. If I was in your shoes though, I would experiment with sticking a spacer in there to fill the gap. Or, can you flip the shear clip and move it in tight?
-Andy Turner
RV-10 N784JC
