Old 09-30-2014, 02:42 PM
walkman's Avatar
walkman walkman is offline
Default Best way to finish off steel braid hose on non fitting end
I'm building new hoses for a variety of things. I also have a couple of existing hoses with this issue.
These are stainless steel braid over teflon with AN fittings on one end, but the other end is a push-on fitting with a hose clamp.
What is the preferred method of finishing off the braiding on the non-fitting end?
On a couple of (non-FWF) hoses I have now, the non-fitting end rapidly sprouts a halo of spikes which are a real (literal) pain when working anywhere near them.
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 09-30-2014, 03:48 PM
SMO's Avatar
SMO SMO is offline
I would use something like this:
http://www.summitracing.com/int/parts/spe-2268
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 09-30-2014, 05:25 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I've used heat shrink to cover the cut ends of braided hose to keep it neat. Looks trick, and it only takes an inch or two of heat shrink.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-30-2014, 05:28 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
You could try a couple of layers of the heaviest wall heat shrink you can find.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-01-2014, 08:54 AM
HFS HFS is offline
Default Heat Shrink Tubing - With Adhesive
You can buy - McMaster-Carr comes to mind, heavy wall shrink tube with an internal heat activated adhesive. The intended purpose of the adhesive is to act as a sealant, but in the case of shrink tube going over something entirely smooth like a hose cover (no bumps to "fix" the tube to the cover once shrunk), the adhesive will "glue" the shrink tube to the hose permanently.
David Howe
Old 10-01-2014, 09:09 AM
Ironflight's Avatar
David Howe
Thanks David for amplifying - yes - I used the heavy walled heatshrink with adhesive. My crankcase breather lines are braid-covered convolute hose from Tom Swearingen, and since it just goes on to a nipple on the engine, I finished the ends with the big, adhesive heat shrink.
Paul F. Dye
Old 10-01-2014, 09:28 AM
Heat shrink, or firesleeve tape works well.
Tom
Ridgeland, SC
