Old 09-30-2014, 11:50 AM
patterson patterson is offline
Default Series of bizarre symptoms
After takeoff I noticed that my EGT on one cylinder was going very lean then it would richen up all by itself. I was working on stabilizing the mixture and soon the engine started missing, even at full rich. I did a mag check and the one Light speed Plasma ll seemed to be the problem. Ran fine on the single mag. As I headed back to the airport to scrub the flight everything returned to normal, except the voltage from the alternator dropped to around 12.7 and never got back above 13.1
Landed without incident but very confused by these apparent electrical issues. I should note that I had another alternator issue some months ago and I replaced it, plus a battery, with new ones. Any ideas what might be the problem?
Ron
Old 09-30-2014, 12:32 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Fuel injection, or carb??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-30-2014, 12:38 PM
Ralph Inkster Ralph Inkster is offline
First thought Alt & Ign symptoms are coincidental but not related.
Ign
1, check plug resistance to see if failing.
2, check spade connectors on ign coil, if one spade black, replace the female side & clean male side with sand paper, coil may have to be replaced if too corroded.
3, check plug wire.
Voltage drop
I'd check all connections on the Master circuit, something might have been jarred while making the lAlt repairs.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 09-30-2014, 12:47 PM
SHIPCHIEF SHIPCHIEF is offline
Lightspeed ignition runs off from Ship's power.
Your problem with the ship's electrical system might not be the alternator or regulator, it could be the main contactor has gone to high resistance, or some other critical connection is going bad.
Shutting off one Lightspeed unit reduced the electrical load (at least on that branch circuit), allowing the line voltage to the remaining ignition to remain high enough to function properly?
Sounds like you might have a dangerous condition.
For example, if one circuit breaker powers both lightspeed units, and it is going bad.
Or, it's possible the voltage regulator is working fine, but a high resistance exists on the line back to the battery, so reference voltage to the regulator is 14+ but battery voltage is low.
Like Ralph says in the post above, check connections for high resistance or indications of heat damage from high resistance.
Tracking down electrical gremlins can be difficult and time consuming, but if you do it, you will know your electrical system better.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 09-30-2014, 12:57 PM
Mike S's Avatar
Senior Curmudgeon
Sounds like it is a one mag, one LS. system.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-30-2014, 02:13 PM
Default Mike is right
I have a newly installed fuel injection (AFP150). I thought the rough idle at startup was just the FI. The runup was fine.
R
Old 09-30-2014, 09:16 PM
Sorry I blew it on the Mag/Lightspeed.
You might look into the archives on lightspeed failure modes as well.
Scott Emery
2019
Old 10-01-2014, 08:03 AM
mahlon_r mahlon_r is offline
Sounds to me as though that cylinder was running on one sparkplug causing the high EGT and then the second plug started to fire and the EGT returned to normal., Bad plug or cable possible in my mind. definitely worth checking....
The voltage change could be the regulator. Some will normally allow voltage to be a little high when cold and then drop the voltage a bit after they get warmed up.
Could you have two separate issues?
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 10-01-2014, 09:01 AM
jjconstant's Avatar
jjconstant jjconstant is offline
May or may not be specific to the symptoms you're seeing, but I had egt symptoms that were variable and baffling and I finally checked the egt sensor itself and it was toast. Very easy to check and fix (order new one!).
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
