Old 09-27-2014, 08:46 PM
Default Importing Homebuilt From Canada Into US - Process?
Not sure this post is in the right forum, but we'll give it a whirl...
I've been asked by an acquaintance who is a US citizen what the process would be for him to import a homebuilt aircraft into the US. The aircraft he is considering is a plans-built airplane and was built in Canada something like 35 years ago.
If anybody has done this before and can give guidance it would be most appreciated as I didn't know where to advise him to start looking, other than going to EAA.
Thanks in advance for your well-considered and helpful replies.
Old 09-27-2014, 11:01 PM
SMO's Avatar
SMO SMO is offline
Just sold my Decathlon into Australia. The process is here:
http://www.tc.gc.ca/eng/civilaviatio...xport-2039.htm
Not sure of all the differences with an amateur built (ie: an Export C of A wouldn't be required), but provides some basics.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 09-28-2014, 07:05 AM
Mel's Avatar
Mel Mel is offline
I'm in the process of certificating 2 aircraft today that have been imported from Canada. First you must deregister the aircraft from Canada. Then you must get the aircraft registered in US.
The aircraft must meet all US requirements for amateur-built status. i.e. the applicant must show proof that the aircraft was 51% amateur-built and sign an eligibility statement (FAA form 8130-12).
If the aircraft has been flown more than 40 hrs. and has not been modified then the Phase I flight testing will be waived.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-02-2014, 06:13 PM
Thanks for your input, Mel. Would appreciate any guidance you might be able to provide with respect to proving the aircraft is 51% amateur-built, particularly an aircraft which may have been built 3 or 4 decades ago; build records often disappear over that many years.
I'm open to suggestions as to how this might be do-able. Thanks!
Old 10-02-2014, 07:13 PM
RV-4 RV-4 is offline
Default Canada to US
Mark
You may wanna give a call to the MDRA ( Which inspect all Homebuilts in Canada) they may have records of the require inspections you're looking for.
A friend is selling his RV-4 and had a few inquiries from the States so He ( I ) will be interested to know how it went for you and your friend..
Keep us posted.
Bruno
rv4@videotron.ca
Old 10-02-2014, 07:41 PM
Thanks, Bruno. The aircraft in question was built long before MD-RA was even a twinkle in Transport Canada's eye. And long before the various stages of inspection were required. I've already done an ATIP request for all of TC's records so I think I've got that base covered. Still not sure what the FAA/DAR would find acceptable as proof of the 51% requirement. This aircraft has only ever been offered as a plans-built aircraft so there's no confusion around fast-build/slow build etc.
Old 03-04-2015, 12:42 PM
flyboy1963's Avatar
Default other problems imminent....
I'm not sure the aircraft would even FLY in the U.S.....
it just wouldn't run right on that cheap Avgas, nor properly go around TFRS and MOA's, and likely the radios would be unable to transmit unless the correct enunciation used:
"...by gar, she's aboot fife towsand feet'n clear here, eh!? "
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 03-04-2015, 01:56 PM
rapid_ascent rapid_ascent is offline
I was wondering that too.
I was once on a trip to Toronto and the waitress at a resturant was very friendly and was making fun of our accents. I thought it was really funny since I thought we only did that of Canadians.
Pretty fun Eh?
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 08-27-2016, 03:42 AM
MattK MattK is offline
Default canada to us
Mel, if the airplane was built in the US with Airworthiness and registration then imported to Canada. Is it easier to import back to the US based on its previous history as a US airplane? RV 6 in this instance
