09-27-2014, 01:06 PM
Camshaft cooling nozzles?
My io-382 is about to be built.
One option is camshaft cooling nozzles.
Do these provide any real benefit to engine or cam longevity?
Tom H.
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
09-27-2014, 01:39 PM
My understanding is that lycoming engines have some difficulty getting sufficient oil to the cam shaft because of its position up top and as a result, frequently show pitting and wear. "Ney nozzles" provide additional oil to this area and are recommended by many, including Mike Busch (see his EAA webinar "All About Oil")
09-27-2014, 02:17 PM
I have them in my IO 360 A1A. There have been some nay sayers on this forum with nothing but "I heard" comments.
I have had them for 1000 hours, no problems. I have nothing but good things to say about Chuck Ney.
09-28-2014, 10:28 AM
Nozzles
Tom H.
The cam nozzles are for lubrication not cooling. Some angle valve Lycomings have piston cooling nozzles, similar but different purpose.
Google Ney Nozzles for a lot of information on this subject.
09-28-2014, 02:33 PM
The Lycoming has a tendency to eat up the cams and followers. Lycoming Flyer has several articles about it. I would do it if I had the option.
member 1 of 6
Metal Feathers Club
RV 7 N706CB
1st flight Oct 18, 08
S/N 72847 tip 200HP CS glass IFR
09-28-2014, 07:18 PM
Fly the plane and you have nothing to worry about. Even with a Cam lube nozzles, if the cam and tappet bodies are allowed go dry... then rusts and pits, you will have the same issue.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
09-29-2014, 07:45 AM
I think they provide great benefit. I wouldn't build and engine for myself with out them.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
09-29-2014, 08:05 AM
Mahlon,
Did all the Mattituck TMX engines cone with nozzles?
Therefore, does mine have nozzles?
BTW, good to see your voice again!
 . CJ
The experiment works!
09-29-2014, 08:26 AM
When I had my engine built by JB Aircraft in Sebring FL, he recommended this be done. He had ECI modify the case for the cam squirters. Here is a picture of them. You can see the little gold colored nozzels below the cam. Thread on the rebuild here.
Kahuna
6A, S8 ,
Gold Hill, NC25
09-29-2014, 11:58 AM
Thanks to all for your feedback. Hearing Mahlon's comment just cemented my decision to have them added during the build.
Tom H.
Good Luck,
Mahlon
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
