Old 09-26-2014, 04:03 PM
Burf09 Burf09 is offline
Default Where can I find a tach sensor?
I have a DPS smart tach. It had a digital display. I'm hoping someone can tell me where I can find the rpm sensor that threads into my slick mag for a DPS smart tach?
Old 09-26-2014, 05:50 PM
RV6_flyer's Avatar
I purchased an UMA tach sensor for my LASAR mag and Dynon EMS D10. I am out of town and do not have the part number with me. The one I have may be the same one that AFS use to use in their older engine monitors.
Found this at Aircraft Spruce. It looks just like what I am using. One wire gets Aircraft Bus voltage, one wire is ground, and one wire is the output signal.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-28-2014, 09:48 PM
Ok thank you I will try that. I wasn't sure if it had to be a specific sensor for the digital display.
