  #11
Old 10-18-2006, 10:53 AM
Default FWIW - Subbies use #6
Originally Posted by sprucemoose
Randy,
Your observations about Skytec starters are spot-on. A kickback can not only damage the guts, but in my case, the entire cast housing cracked from one end to the other.
This issue has been done to death, both here and on the RV List. Bottom line is that if you are running one of the new, smaller batteries (ie. Odyssey of Panasonic) and a lightweight prop, then the flyweight Skytec is not a good starter to use. Especially if you run 4AWG wire for the starter (there- brought it back home.)
In the Subaru world, #6 is working just fine, and this with a compression ratio of 10:1.
But of course the engines start real quick.
dd
RV-7A
H6
Old 10-18-2006, 03:07 PM
Bill Dicus Bill Dicus is offline
Default Starter wiring
Anybody know if the #4 would be ok for a B&C starter on my 10:1 comp IO360? Thanks for any info you can ante. Bill
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 10-19-2006, 10:13 AM
RickS RickS is offline
Default Thanks all... # 2 it is...
Appreciate the responses and different experiences, given that the starter on the plane may be changed eventually and so may the battery it seems prudent to use no 2 gauge wire to cover all eventualities and make the starting system that much more robust.
I'll just use the #4 as the alternator output cable...
Thanks again,
Rick
Old 11-01-2006, 02:48 PM
Default Starter cable
Apologies to all for stupid question about #4 to B&C starter; should have read paperwork with the starter. It specifies #2 from solenoid to starter. Bill
Bill Dicus
