Old 09-25-2014, 04:01 PM
Freightdawg's Avatar
Freightdawg Freightdawg is offline
Question Match Drill vs. Final Drill definition
OK, I thought I understood the difference between match drilling and final drilling, but page 15-4 has me doubting that. I thought match drilling meant one piece of metal had a hole and the other didn't, so you use the established hole as a guide in drilling; final drilling meant both pieces of metal had holes but the holes needed to be enlarged to final size.
If I have the definitions correct, step one calls for match drilling where all the parts already have holes in all the pieces.
What am I missing?
Thanks.
Jeff Rich
RV-10 KJVY
N313KC registered
Awaiting Airworthiness Inspection--soon! (fingers crossed)
Old 09-25-2014, 04:11 PM
aarvig's Avatar
aarvig aarvig is offline
Number one: Make sure you indeed have the right parts.
Number two: I came across this during my build. Instructions would ask me to do something that very obviously had already been done. If this is the case, refer to the plans and final drill to the appropriate size.
If you are in serious doubt, call Vans.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 09-25-2014, 04:33 PM
flion's Avatar
flion flion is offline
Sometimes 'match-drilling' means final-drilling through two matched pre-punched holes. 'Final drilling' may mean drilling out a single hole to final size, like some screw holes in parts on the RV-10. If I read through the plans through the whole relevant assembly, it usually is fairly clear what they mean. English is not an exact science.
EAA Technical Counselor #5357
Old 09-25-2014, 07:28 PM
Jesse's Avatar
Jesse Jesse is offline
Match drilling does refer to using one hole as a guide to drill a new hole in another part. Final drilling is opening up an undersized hole to final size, whether in a single piece or multiple pieces. I wouldn't be surprised if they have made some mixing of those terms with the number of times they are used in the plans, but it is also possible that in earlier versions of the kits it truly was a match drill and now is a final drill because they have changed some of the parts.
Jesse Saint
Old 09-26-2014, 07:05 AM
Thanks for the replies.
Jeff Rich
RV-10 KJVY
N313KC registered
Old 09-26-2014, 08:17 AM
sahrens's Avatar
sahrens sahrens is offline
I would add there are locations were you need to match drill two or more parts and then drill to a much larger size. For example, the pre-punched hole is 3/32 but ultimately the fastener is a AN509 or larger.
Match drill the parts to establish the proper alignment and fit. Then drill to final size.
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
