Old 09-23-2014, 03:20 AM
PIN 37 PIN 37 is offline
Default 3/32 pulled rivets
I have been looking Spuce and Vans for 3/32 countersunk blind/pulled rivits but without luck, does such a thing exist and if so, from where?
Phil
LAME (Aust)
RV7 99% finished
Old 09-23-2014, 04:46 AM
Ultra's Avatar
Ultra Ultra is offline
i know a brand called Advel make a pull through type 3/32 blind rivet, the only ones i have seen are steel countersunk
http://www.avdelusallc.com/products/...ntersunk.shtml
if i remember to look at work tomorrow, ill find out where our Aussie supplier is..
Old 09-23-2014, 05:32 AM
Tony Spicer Tony Spicer is offline
Available at Spruce.
BSC-34 or CCC-32
For large quantities, here's the place to go. Don't know if they ship to AU.
Tony
Old 09-23-2014, 07:10 AM
rwarre rwarre is offline
Default How many
I have some left overs if you don't need a lot.
Old 09-23-2014, 07:37 AM
daveyator daveyator is offline
In the RV12 kit, Vans supply a 3/32 countersunk rivet used generally for holding nutplates where a squeezer can't reach. The mandrel pulls right out, leaving a hollow rivet. I had problems getting them tight until i used a cherrymax puller on them. Don't have any info on the strength. Haven't got plans handy, but as I recall, they are designated ccr264ss.
hope this helps.
cheers, DaveH
120485
Old 09-23-2014, 07:45 AM
lr172 lr172 is offline
They are referred to as CCC32 on ACS. Pretty sure they have some in longer lengths as well as a BSC version.
Larry
Old 09-23-2014, 07:53 AM
Mike H Mike H is offline
There are no "structural" rated 3/32" blind rivets, however MS20605 series rivets are used for attaching nut plates and secondary structural applications. There is no published data that I can find as far as shear and tension strength for these rivets, but they are plenty strong, especially the CRES steel alloy rivets.
If you decide to go this route you may want to check with the engineers at Vans prior to installing the fasteners.
http://www.everyspec.com/MS-Specs/MS...MS20605N_8073/
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 09-23-2014, 12:00 PM
XOverZero's Avatar
XOverZero XOverZero is offline
hope this helps.
cheers, DaveH
120485
They say: CCR264 are only intended to keep the nut plate from turning, not a structural application...and, doesn't matter if it looks a little sloppy, it get covered up by whatever attaches to the nut plate so you can't see it. That's what I've heard said.
OK, I suppose it's just me, but I don't really want to expend all my best efforts and end up with something that looks shabby, and I especially don't want that in a place where I can no longer see it. Ergo, it didn't take long for me to learn to despise those CCR rivets.
One could lay out the $100++ for a Cherrymax puller. That's a lot of loot for a tool that only performs one specialized function. For much less than that, I bought a used C-frame with the rivet set holders. I use it to drive solid rivets in nut plate locations that are accessible with it. It does that as well as all other tasks for which it is designed.
Now, if I could just find a way to use it on nut plates that go into pre-joined panels...
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2021
Old 09-23-2014, 05:45 PM
Originally Posted by Mike H View Post
There are no "structural" rated 3/32" blind rivets...
Nor are there any structural pulled rivets anywhere in the RV-12.
Tony
Old 09-24-2014, 03:27 AM
Thanks for the answers guys, the rivits dont need to be structural as they are only holding nut plates, but they do need to be countersunk. Cheers.BSC-34 or CCC-32
PS. Are the BSC-34 or CCC-32 countersunk?
Phil
LAME (Aust)
RV7 99% finished
