Just a note to say that the adhesive failing will NOT result in a structural failure, just in a maintenance headache you have to disassemble.
We've installed clickbond studs at work using double-bubble packets REALLY close to the 105MM howitzer to secure instrumentation wiring on an AC-130 in a pinch, seems to work just as well as the $$ click-bond stuff. I've also used Hysol 120HP and similar with good results.
On my RV and in race cars I've used the plastic and foam tape sticky pad zip tiedowns with the junk tape ripped off and double bubble, hysol or JB weld with a 100% success rate (so far).
Macon, GA (KMCN)
RV-7, Niner Fife Victor
