Old 09-22-2014, 04:22 PM
dekagram dekagram is offline
Default Slick 500 Hour Inspection
Can anyone recommend a shop in or around New Orleans that can perform the Slick 500 Hour Inspection?
Thanks in advance...
N72GS
Old 09-22-2014, 05:44 PM
flyingriki's Avatar
flyingriki flyingriki is offline
I'm sure there is a good shop near you but Aircraft magneto Service in Washington does great work, is a terrific guy with many, many years experience and a hoot to chat with, get tech help from.
Old 09-22-2014, 10:34 PM
Bavafa Bavafa is offline
N72GS
I just had mine done at Crossfire in Loveland Co. and they came back as if they were brand new. The service was very quick, they did a great job and were very accomodating in any questions I had regarding the re-installation or any thing else. Highly recommend this place.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-23-2014, 04:29 AM
Jesse's Avatar
Jesse Jesse is offline
I have always used Quality Aircraft Accessories in Tulsa. Www.qaa.com
Jesse Saint
Old 09-23-2014, 10:50 AM
Mike H Mike H is offline
The cost of the Slick manual and the two tools you need to do the job yourself is less than $50.00 Very easy to do and you get to learn something new Ha! I should have been a Hip Hop "artist" instead of an aircraft mechanic!
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 09-23-2014, 11:47 AM
Walt's Avatar
Walt Walt is offline
$50, are you sure?
3.3 500-HOUR INSPECTION
Follow instructions in Section 5.0, Removing Magneto from
Engine. All procedures needed to perform the 500-hour
inspections are detailed in Section 6.0, Magneto
Disassembly and Section 7.0, Magneto Assembly.
2.0 REQUIRED TOOLS
T-100 Assembly and Timing Kit includes:
P/N Description Qty
T101 Bearing Assembly Plug 1
T102 Rotor and Frame Assembling Plug 1
T103 Oil Seal Assembling Plug 1
T106 Puller 1
T117 Base Adapter Plate 1
T118 Timing Pin 1
T119 Bushing, Adapter Plate 1
T121 Bearing Puller (2 Halves 1
T122 Wedge extractor 1
T123 Timing Plug 1
T125 Assembly Fixture 1
T150 "E" Gap Gauge 1
T151 Cam and Rotor Set 1
T152 Spacer 1
T153 Alternate Cam and Rotor Set 1
T155 Rivet Gauge 1
T509 Spacer (included with T125) 1
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-23-2014, 12:18 PM
rocketbob's Avatar
I have the T-100 tools and have never found it necessary to use to do a 500 hour check. Unless the seals are leaking I wouldn't pull the rotor. Mainly one is checking the timing, for evidence of arcing, the condition of the cam, follower and points, the egap, and the condition of the impulse coupling pawls and rivets. I guess I don't understand why people make this complicated.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 09-23-2014, 12:24 PM
Sid Lambert Sid Lambert is offline
Hear, hear.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 09-23-2014, 12:30 PM
Pretty much exactly what Bob said. I don't have a copy of the manual in front of me now but I do not recall having to use any of the referenced tools except the T-150 E-gap timing tool during the inspection unless you find a problem with a bearing or a seal. I honestly do not see why most people do this inspection on a Slick mag, they will usually tell you when they have a problem. In the very few cases where you have a complete failure of a coil or a condensor you usually either had lots of warning prior, or it happens really fast and an inspection that was performed 50 or 500 hours ago would not have found any electrical defects. I run them 2000 hours and replace them with new units. We have a flight school here that runs R and S model 172s to TBO every few years and almost never remove a mag between TBO.
Mike Hammond
A&P IA PPL ASEL
Old 09-23-2014, 12:43 PM
rocketbob's Avatar
One other thing to inspect for. Carbon arcing covered under the soft distributor brush AD.
N8155F C150 flying
