09-21-2014, 01:59 PM
Loctite 567 cure time
I'm having a heck of a time with leaky master brake cylinder fittings. I'm going to try loctite 567. Is there a cure time before putting brake fluid back in?
Michael
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
09-21-2014, 02:19 PM
Me too. Tried 567 and a couple other - no joy. Finally gave up, took my tech advisers suggestion and used teflon tape  , that worked....
Vic
09-21-2014, 02:32 PM
I'll pile on. I redid mine a few days ago with 567 and the squeeze out is still "wet". Should it have "firmed" up by now?
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
09-21-2014, 02:57 PM
I could be wrong but I seem to recall that the connection can be put into service immediately. Check the fine print.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
09-21-2014, 03:29 PM
Try Loctite 545
Bevan
Yep, 567 is good stuff. It does take a few days to fully set up but usually it will seal fine even when still "wet". But I didn't use any on my airplane.
For brake fittings that are pipe thread I use Loctite 545 Hydraulic sealant.
This stuff is better for the smaller "finer" threads. It cures pretty fast.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
09-21-2014, 04:06 PM
What causes the leak? Notch in threads? Inadequate depth to fully engage the taper?
Anyone know?
Bill
RV-7
Lord Kelvin:
09-21-2014, 04:52 PM
Directions...
According to the following directions. Loctite 567 needs to cure for at least 24 hours to reach full strength. It does have immediate sealing strength. But to be safe it sounds like 24 hours would be best.
Also it sounds like cleaning is important.
http://www.kvc.com.my/EnterpriseChan...octite-567.pdf
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
09-21-2014, 06:53 PM
After a couple iterations I ended up using proseal fuel tank sealant on one of my fittings to get it to stop the drip
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
09-21-2014, 10:06 PM
567 is an anaerobic adhesive. The stuff you see around the threads after assembly will never cure fully, because it's exposed to air. The stuff in the joint will cure quickly. Full strength comes after 24 hours, but well before that you'll find that if you try to disassemble the joint it will come apart far more grudgingly than it went together. I use 567 all the time in the hydraulic assemblies I put together at the place that supplies me with the money that I need to keep my RV-7 airborne. It works very well- our environment is 5000 psi and a shake table with 21g acceleration.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
09-21-2014, 10:22 PM
I too used 567, had leaks. Mostly caused by not tight enough fittings. I ended up turning the two fittings in one more rotation and that sealed them up. Fingers crossed, because it ain't no fun head first diving in the front of an 8 to fix leaking brake fittings!
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
