Old 09-20-2014, 10:52 PM
SMO's Avatar
SMO SMO is offline
Default High Fuel Pressure - IO-540
My fuel pressure alarm went off today because the fuel pressure exceeded the upper alarm limit I had set in my VP200 (fed by GRT EIS).
Here is a graph of the hour long flight Fuel Pressure is the green line.
As you can see, the pressure is quite erratic on the high side upon startup, for the climbout, and for a few minutes after and then settles out to the normal range. It spikes once over 45 lbs just at the beginning of runup, and again over 40 lbs as we begin cruise.
I looked at graphs of previous flights and looks like it started acting up 2 - 3 hours ago and has been getting worse. I suspect the sending unit is the problem, or connections to it, but is there anything else that could cause this? I can't imagine the fuel pump actually putting out this much pressure but..........................???
The boost pump is on only for a couple minutes during climbout and again during landing.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 09-21-2014, 01:51 PM
Jesse's Avatar
Jesse Jesse is offline
First I would check to see if it happens only when the boost pump is on, only when the boost pump is off or regardless of the boost pump. If regardless, or when the boost is off, then I would certainly expect a sender. It could be a loose wire or a bad ground.
Jesse Saint
Old 09-21-2014, 03:15 PM
dmaib's Avatar
dmaib dmaib is offline
I agree with Jesse. Also, the GRT senders seem to fail in the mode you are seeing fairly regularly. I have replaced a couple of them in the last five years.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
