Old 10-16-2006, 07:58 AM
mistergerf mistergerf is offline
Default Aerodynmic RV-6/7/9 external canopy latch ?
Some weeks ago I saw a company selling a replacement external slider canopy latch which is much more aerodynamic (and better looking) than Van's original. I've hunted high and low and can't find the website again - any one got any ideas ?
g
Old 10-16-2006, 08:22 AM
mandm1516's Avatar
mandm1516 mandm1516 is offline
Is it this one?
Canopy Handle
Mike
Old 10-16-2006, 09:46 AM
Default Thanks !!
That's the one !! - Now I'm $30 the poorer ...
Old 10-16-2006, 10:47 AM
Default The one in the picture has an operational problem
WOW $30! can't you grind/file your own Van's supplied handle? If you do not modify your new handle you or someone will eventually slide you canopy forward and damage your windshield bow fairing with the handle that has the tail end pointing forward. To prevent this remove material from the bottom of the tail end of the handle until it completely clears the bow fairing when the handle is pointing forward.
Bob Axsom
Old 10-16-2006, 04:24 PM
rv969wf's Avatar
rv969wf rv969wf is offline
Default Modified stock VAN's handle / latch
This was a stock VAN's handle/latch that I machined and streamlined on my -6 and like Bob mentioned the stock latch will damage your plane if it isn't facing rearward when you close the canopy. The profile I did to mine prevents this from happening. Just wanted to pass on a couple of pictures if your curious. Good luck.
Alan (AJ) Judy
Beaver, OK in NO MANS LAND
RV-6 IO360A1B6 C/S Hartz 200HP ?
Also Fly North American NAVIONs
Race car engine builder/Machinist/Fabricator 1982--present.
