Old 04-09-2005, 09:54 AM
Bill Hutton Bill Hutton is offline
Default Tip Up Canopy Guide(s)
Anyone have ideas for a canopy guide for closing of the tip up? Have seen the one in the 10/94 RV-Ator, but am looking for more ideas or suggestions. Am flying a 7 and want to eliminate the right rear corner of the canopy hitting the roll bar as it closes.
Bill
RV-7, N627RV
Old 04-09-2005, 10:33 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I don't have any photos, but I've seen 1/2" AL angle used as a guide. It is split and rolled inward so as the edge of the canopy nears the roll bar, the angle guides it over the edge of the roll bar as the canopy continues down. It basically wedges the canopy out so by the time the corner of the canopy passes by the roll bar, it is lined up. The pieces are about 3" long and are usually pop riveted on. I did not find a need for them as my canopy seems to close fairly well by just pushing inward as I lower it from one side. Lowering from the handle while in the cockpit seems to be just fine.
Van's uses this style. Maybe someone has pics or a better idea.
Roberta
Old 04-10-2005, 08:40 AM
ClayR_9A's Avatar
ClayR_9A ClayR_9A is offline
Default Canopy guide blocks
Here's what I did for my tip-up. One on each side. Works great.
http://www.eaachapter.com/RV9A/Final_steps2.htm
-Clay
Old 04-10-2005, 09:49 AM
I like that idea. Best I've seen.
Roberta
Old 04-11-2005, 07:46 AM
Thumbs up
Thanks Clay. Clean, simple fix. Will give it a try.
Bill
Old 04-14-2005, 07:00 PM
arffguy arffguy is offline
Good photos and ideas. And that is a great collection of various RV color ideas too. Thanks!
