Old 09-12-2014, 08:11 PM
bobnoffs bobnoffs is offline
Default choice of alum. alloy
i want to make a few reinforcements, doublers, backing plates. angle is usually seen in 6061 and i plan to use 2024 for the plate alum. is there really significant difference in the 2 alloys to choose one over the other for reinforcing certain areas? i am thinking of 1/32 or 1/16'' stock
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 09-12-2014, 08:29 PM
Jesse's Avatar
Jesse Jesse is offline
I assume you're talking about 6061 T6 and 2024 T3. I am sure you will get much more technical answers, but here's the short version. 6061 is softer and more pliable/bendable in its heat treated form T6. 2024 is stiffer/stronger but less pliable/bendable in its heat treated form T3. 6061 is weldable. 2024 is not.
Jesse Saint
Old 09-12-2014, 08:48 PM
Mel's Avatar
Mel Mel is offline
6061 is also much more corrosion resistant. Hence why 2024 is usually alclad.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
