09-08-2014, 09:31 PM
Filling stall warning holes
I tried searching old threads using various search strings but never found anything.
I have a QB8 wing that has the holes for the stall vane already pre-punched. I will be doing an AOA system (don't know which one yet) so I need to close these holes up. I have some ideas of my own plus some suggestions from local builders but wondered what others have done to close up these holes. Just looking to see how others have done it.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
09-08-2014, 10:47 PM
I am building a 6, so don't have this issue. If you can get access behind, I would rivet on a .025 backing plate and fill with filler. You can use HSRF if you don't think standard polyester filler will be strong enough. The HSRF is very strong with a tenacious bond.
Larry
09-08-2014, 11:03 PM
Holes
Can't you just prepare the holes and put in a rivet?
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
09-08-2014, 11:24 PM
Robert, the hole is about 1"x2" big enough for the stall warning divide to mount and catch air. It will be a job to hide it, but can be done.
Correction - I went and looked at my wings today and the opening is about 3/4 x 3/4.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Reason: error in measurement
09-09-2014, 12:12 AM
Perhaps a cut-to-fit flush patch the same thickness as the skin, and a doubler behind it flush riveted to both the patch and the skin?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
09-09-2014, 08:44 AM
Stall switch
Why not install the stall switch and use it as a backup?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
09-09-2014, 09:21 AM
Exactly what I did about 2 weeks ago. I made the backing plate to fit the existing rivet holes and filled the slot with West Systems epoxy and micro. It's now painted and you can't tell it was ever there.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
09-09-2014, 09:42 AM
I might be remembering this wrong, but when I received my -8 wing kit the vane opening wasn't pre-punched. The leading edge skin included two small (1/8"?) locator holes for this opening. The vane opening was created by removing the material between these holes. My comment assumed the OP was only filling the locator holes.
Robert
Robert Williams
Lee's Summit, MO
Working on Fuse
O-360-A1A
1946 Cessna 120
09-09-2014, 09:57 AM
I am confused.......the opening in the leading edge for the switch is something like 3/8" x 3/4, not 1" x 2. Are we all talking about the same thing here? Or do different models have different switches and openings?
-Andy Turner
RV-10 N784JC
09-09-2014, 12:27 PM
Robert
This is what I have. Two small (undersized #40) holes in the leading edge that you would open up and connect to make the slot if you were going to install the vane and then some other pre-punched holes trailing back from the leading edge to secure the internal bits of the vane assembly.
Dimpling and filling with rivets is certainly one of the possibilities but wondered if others had come to a more elegant solution.
Sam
Fuselage underway
N18451 reserved
