Old 10-14-2006, 05:07 PM
Walt's Avatar
Walt Walt is offline
Default Installing LSE direct crank sensor question
I am going to switch from my Hall effect module to a direct crank sensor due to the fact that I am on my 3 module, all replaced due to seal leakage. So my question to those that have done this is just how hard is it to drill and tap the holes in the case? I have a solid flange crank so it looks like an angle drill and using a tap with a wrench will be the only way to get this accomplished. Any guidance from those that have gone before me would be appreciated!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-14-2006, 07:42 PM
AlexPeterson's Avatar
Walt, having just done that this past spring, I can tell you a little. I have the O-360 with C/S, so I can't speak to similarities to the other cases/cranks.
On mine, in order to get a straight shot with the drill, I had to remove one of the threaded bushing in the crankshaft flange. This was not difficult, I used a grade 8 bolt, some steel bars and a large C-clamp. Without removing the bushing, it would not have been possible. I taped the Lightspeed pickup plate in place, and using a transfer punch, put a good centerpunch drill starter dent in one of the holes. I then removed the bracket, drilled and tapped one hole. I believe the instructions state how deep to drill. Use a good quality plug tap. Use plenty of oil, and take your time. Protect the recess where the crankshaft seal is from chips. Once one hole was tapped, I bolted the bracket back on, center punched the rest and drilled/tapped.
I'd send the ring gear assembly to Klaus for drilling and fitting the magnets, as some need a little fill welding.
Good luck!
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 09-21-2008, 11:37 AM
cjensen's Avatar
cjensen cjensen is offline
Did a search on this subject, and only found this one thread that related close enough to what I'm about to do...
Alex, can you elaborate a bit more on what you did to remove the bushing? It sounds easy, but I want to make sure I do it right...this is the crank afterall...
Any other threads or advise on this is appreciated!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 09-21-2008, 12:25 PM
Walt's Avatar
Default If you Happen to have an ECI motor....
When I took my flywheel off I was elated to see that ECI had already drilled and tapped these holes, everything fit together perfectly
Old 09-21-2008, 02:07 PM
cjensen's Avatar
Well...as it happens, I do have an ECI motor, EXCEPT the case, which is Lycoming. All other parts are ECI...still need some advise/direction here...
Chad Jensen
Old 09-21-2008, 04:33 PM
breister breister is offline
One other suggestion - use a lock-washer AND Loctite. Once installed, you should never have to remove it - but getting the spacing exactly right was a PITA. We measured over a dozen times and were SURE we were right in the "sweet spot," but no spark. Reducing the spacing by an amount equal to 1/2 of what we THOUGHT it was (and checking carefully with carbon paper to insure no scraping) resulted in perfect spacing and spark. Once that is right, lock it in good and forget about it.
Old 09-21-2008, 06:28 PM
cjensen's Avatar
All I really need to know here is how to get the bushing out...anyone???
Thanks for the advise on the spacing though!
Chad Jensen
Old 09-21-2008, 08:16 PM
Noah's Avatar
Noah Noah is offline
Hi Chad-
Use a large C-clamp and a short piece of stiff / strong tubing or pipe whose ID is slightly larger than the bushing. Use the C-clamp as a press or squeezer to push the bushing into the tubing. Just make sure the ends of the tubing are cut square. I've seen photos of this somewhere, can't find them at the moment.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 09-21-2008, 08:44 PM
Chad, I used a socket head cap screw of the proper thread. I screwed it into the bushing, engaging all threads, and then used a big ol' cast iron 8" c-clamp to push it out. I used also a large socket as a spacer when necessary. Used the same big bolt to pull the bushing back in. Just bring a collection of sockets, bars, spacers, etc. and it will be easy.
Alex Peterson
KADC, Wadena, MN
