09-03-2014, 07:23 PM
Gretz Pitot Mount Question
I purchased the Gretz mount for the Pitot. This is not made of aluminum, so I assume that I should prime it before installing it. If it should be primed, then what should I use? Akzo, SEM, etc?
thanks
Ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
09-03-2014, 09:29 PM
Primers
Whatever you have. Akzo would be best.
I had mine powder coated Vans white.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
09-04-2014, 02:34 PM
that is a good idea. I think that is what I will do as well.
Ken Stockman
Midland, MI
N73XP
09-04-2014, 09:07 PM
Powder coat
I had all the parts done after it was fitted. I had to adjust to adjust the wing hole just a bit due to the thickness of the coating but it looks great. The Vans color is Cardinal GR230.
Larry Larson
Estes Park, CO
Disclaimer
09-05-2014, 10:03 PM
You can buy the Van's powdercoat color in spray cans from Cardinal (but they have a minimum order of 6 or 12 cans). I bought a bunch and gave them out to fellow builders for various touch-up or small paint jobs.
Any powdercoating place should have that color in stock, too. I had my instrument panel powdercoated to match...came out great.
ETA: be advised that Van's "white" is not white. It's grey. So if you're going to paint the plane with white basecoat, you may wish to just let the paint shop do the pitot tube mast, as well...or it won't match.
