Mine is one step worse.
With no washers, the locknut on the bottom bearing stud (CM-4S) barely has locking capability. If I added a washer to the other side, it wouldn't lock. By the way, it was horrible installing the locknut. I had to use my entire vocabulary. I'm told that newer kits call for a platenut when constructing the flaps.
I trimmed the fuselage exit hole all the way up to the doubler on the inside of the skin. The pushrod still won't fit. The lower rod end needs to come inboard.
I called Van's, and got a good tip. If you need more inboard adjustment, you can use a different rod end (CM-4M, like the one at the top end). Then use a dash 4 bolt and spacer of the appropriate length to get the rod end inboard where it needs to be.
Craig Mac Arthur
