Old 09-03-2014, 08:52 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Smile Cowl piano hinge ?
Paul Dye reported the use of a smaller wire to ease assembly. A -4 builder told me the hinge eyes break near the front curve. He replaced the hinge twice before installing fasteners. McMaster has .080"SS wire now available. Does anyone know of a better choice before I order? 1lb is 58 feet so there will be plenty share with others.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 09-03-2014, 11:39 AM
Ironflight's Avatar
VAF Moderator / Line Boy
You can buy 3 foot lengths of the slightly undersized wire from McMaster as I recall - we ordered two pieces (each) of several different undersized wires and it didn't cost much.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-04-2014, 10:41 AM
HFS HFS is offline
Question Drill Rod
The under size wire you are referring to is listed in McMaster's product index as "drill rod". The name refers to the actual size of the wire according to the AWG (American Wire Gauge) index, and not to their hardness or brittleness. The same sizing as in your 1-60 drill index - so you can "jump" up or down in size just a few thousanths at a time to either loosen/tighten a hinge joint. Be aware that this material is softer (read - more pliable/ ductile) than the "as delivered" pin, but I have been using them for more than 25yrs and 2500+ of RV service and have never had one fail. (If you have a real tight fit - DON'T spin them in with a drill motor! Bad juju - if you put enough torsional stress on them and they "twist" into two pieces, you now have a permanent joint!)
Although McMaster normally sells them in 3' lengths, they are actually manufactured in 12' lengths and cut down for McMaster for their convenience for shipping, etc. You can special order them in any length you want - for a slight additional cost. I got a bunch cut into 4' lengths for my Rocket cowl back in the late '90's and still have an "inventory" that I use as needed.
The typical pin as received with the hinge is on the order of .089" - drill rod (as I recall - I am not home now, so this if from memory) is available in .088, .085 and so on down the line. Somewhere in there should be a size that will help. Use the "loosest" fit that works for you, and then over time as the hinge eyes wear a bit you can jump up a size (or more) to "tighten" the joint again to your satisfaction.
YMMV
HFS
Old 09-04-2014, 04:09 PM
Thumbs up Thanks HFS
Will investigate the drill rod. Thanks for all the tips. Have not gotten to fabbing a new aileron bellcrank( rv8replacement) but still have your data and plan to do it. Larry
Larry DeCamp
Clinton, IN
