Old 08-29-2014, 11:41 AM
dan carley dan carley is offline
Default air speed needle movement
in my rv4, the asi needle bounces also a little movement in my altimeter. i've only had the rv a little while. i just replaced the asi and it still doing it. does any one know where to look? must be in one of the lines. would it be pito or a static problem
thank you
dan carley
Old 08-29-2014, 11:50 AM
Mike H Mike H is offline
Sounds like a small slug of water in the static system. Remove the pitot and static lines from ALL instruments and blow them out from the cockpit side using low pressure dry air or nitrogen.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 08-29-2014, 12:04 PM
Default asi
i also have a angle of attack system and it has a static port on the top of the left wing. could that be causing a problem?
dan carley
Old 08-29-2014, 12:37 PM
Not unless you tapped into the static system to run the AOA. The AOA system should have its own plumbing for the AOA sense port.
Mike Hammond
A&P IA PPL ASEL
Old 08-29-2014, 04:07 PM
Default asi
i gave that a shot today. it didn't clear the problem. if i keep it about 150 mph it seems to go away
danny
Old 08-29-2014, 04:31 PM
Marc Bourget Marc Bourget is offline
Dan,
Curious, did you use the standard diameter tubing for A/S and Static?
If you used a larger diameter, it may appear more sensitive as there's less flow damping.
FWIW
mjb
Last edited by Marc Bourget : 08-29-2014 at 04:32 PM. Reason: Added ? at end of 1st Sentence
Old 08-29-2014, 05:34 PM
Default asi
no it's standard tubing
danny
Old 08-29-2014, 06:51 PM
Maybe turbulence at static port orifice due to damaged port or chipped paint/irregular surface up stream of port. Do have dual static ports? Have you tried slipping the airplane to see if it changes. Maybe a static leak inside of the airplane that is being affected by the positive pressure from the air vents? Time to carefully inspect the entire static system.
Mike Hammond
A&P IA PPL ASEL
Old 08-30-2014, 12:22 PM
Default asi
i think i found the problem. (not) i have 2 static ports in rear of fuse, they are large rivets. one of the lines came off there for neither port was connected. i rehooked them up and tried it again. still same problem. when at 175 mph it shakes at 2500 rpm but at 2000 rpm 150 mph it's smooth. i'm thinking a vibration from the prop?? i do have one of those little pitto tube covers that open like a butterfly when your moving. could that be causing turbulence by the pitto tube?
dan carley
Old 08-30-2014, 06:12 PM
I have never been a fan of those weather vane/flapper valve type covers, but I doubt it would cause an issue if it is installed and working properly. Do you feel vibration in the airframe when the ASI needle is bouncing?
Mike Hammond
A&P IA PPL ASEL
