Originally Posted by TerryWighs
SNIP... I can't imagine needing to cut the HS 702 front spar...nor would I ?
View B-B on DWG of the -8 plans showes the bend on the front spars at 4 7/16" outboard from the edge (centerline when assembled.) Mine did not have that much length before the start of the flanges. Thats what I trimmed to allow the 6 degree bend in the proper place. Not much needed trimmed, perhaps 3/32 or 1/8" at the most. I suppose if you cut the corner relief cuts as shown in view A-A first, you may be able to get away without trimming the flanges as much.
