Old 10-12-2006, 05:17 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Default Flop Tube Life Span
Hello Guys,
I know there is a recommendation for changing out the flop tube every five years. I finished building my wings more than five years ago and my airplane will be done soon. The flop tube has never seen an ounce of AVGAS. Do I still need to change it out? I thought about swapping it out for one made of Teflon hose but the only draw back I could see is that the Teflon hose would be quite a bit sttifer. Any ideas?
Jerry
Old 10-12-2006, 07:44 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Flop tube life
I have a photo of an old flop tube removed from an RV-4 vs a new flop tube. The main issue I saw is that the flop tube is stiffer then the new one which means that when inverted the flop tube may not settle to the top (inverted is the bottom) of the tank.
http://www.experimentalaero.com/flop_tube_alert.htm
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 10-15-2006, 07:58 PM
RV8Squaz's Avatar
Paul,
Thanks for your reply. I wonder if the hose would have gotten that stiff without being submerged in fuel all those years. My tanks haven't seen a drop of fuel yet so the hose hasn't been subjected to the long term effects of AVGAS. I guess I'll be checking and/or replacing the hose when I accomplish Van's recent service bulletin on safetying the b-nuts.
Does anyone have any experience replacing the flop tube hose with a Teflon hose? I know the Teflon is stiffer, but is it so stiff to prevent the flop tube from operating properly?
Thanks for your help!
Jerry
