Wing Tank bolts
Originally Posted by alpinelakespilot2000
Once your bottom wing skins are riveted on it would seem to me that it would be REALLY tough to get all those bolts in and probably impossible to get a torque wrench on them. My vote would be to just have an extra helper around when you mate the wings. Good luck.
Actually it's not that tough - at least with the wings in their stands  I did the final torqueing and applied torque seal after my wings were completed. Now doing it after the wings are installed would be a job
I also had my tanks installed when I installed my wings to drill the aft spar holes, and I also drilled the holes for the forward tank support bracket. I didn't have any problems mounting the wings with the tanks installed. I've done this a few times now - helped my son when he mounted his wings initially and finally (he's flying now) with the tanks installed. It's an easy job for 2 people.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
