Old 08-25-2014, 07:08 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default Tip-up slider
Does anyone have a web site where they have documented the retrofit of a slider to a tip-up slider? The last thread I found on VAF on this is 2010. And I didn't see any sites listed.
I'm interested in making this mod to the RV-6 I am buying so I can easily get my camping gear in the baggage area.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 08-25-2014, 07:25 PM
RV7ator RV7ator is offline
No pictures, no threads, but it's easy.
Notch each rail 60 degrees included and 3/4 inch deep with the bottom of the notch a 1/16 radius. Set the center 11 1/2 inches aft of the roll bar. Fiddle with this a bit to made sure the latch handle clears the roll bar when tipped.
Notch the t-rail an inch or more fore or aft of where the slider block sits with the rollers just aft of the notch and the brackets are poised to tip into the notch. The idea here is to prevent disengaging the slider and tipping simultaneously because it takes careful aim while lifting to assure the brackets pivot into the notches; otherwise, you bend the rails.
Make a prop rod from 3/16 music wire spanning between a canopy frame pin block and a drilled out rivet in the square tube canopy frame above it.
Radius the forward lower edge of the side skirts 3/8" so they don't dig into the sill.
John Siebold
Old 08-26-2014, 12:25 PM
ccsmith51's Avatar
Thanks, John. You wouldn't happen to have a photo of the notch, would you?
Chris Smith
Old 08-26-2014, 09:18 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Here some info on Gen 2...
http://www.jrwengineering.com/rvinfo.html
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 08-27-2014, 05:50 AM
flyinlee flyinlee is offline
Default tip up slider
I installed the Meski kit on my 6A and it's one of the best mods you can do. Loading from the outside is huge. Very easy to do.
Good luck
Old 08-27-2014, 07:53 AM
Jrskygod Jrskygod is offline
I just finished my JR Engineering install. It was an easy retrofit just follow the directions. The components are first rate, anodized and everything fits. Works great and so much easier to load. also the feature that allows the canopy to slide back a couple of inches for ventilation is very nice as well.
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 08-27-2014, 07:38 PM
Joe Parish Joe Parish is offline
Another option:http://www.aircraftextras.com/tip-up-slider1.htm
Joe
RV-9A N525XC
Superior IO-320
Dynon HDX
Flying as of 5-4-18
Old 08-27-2014, 11:32 PM
Darin Watson Darin Watson is offline
+1 for the JRW version. Installed about 18 months ago and really makes getting stuff in and out a breeze, especially on a tail dragger where it is nice and low. One recommendation on modifying the tee rail is to leave a little at the back so that if you choose to taxi canopy full open the slider is still locked in. Hopefully you get the gist of it below:
_| |_
Regards,
Darin
C-GULF RV-7 located in Calgary, AB
