Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 08-25-2014, 02:57 PM
noelf noelf is online now
Default Sensenich prop color?
I dressed out a small nick in my Sensenich prop and now need to apply some paint to the leading edge. I see that TEMPCO has a gray prop paint in a spray can. Does anyone know if this is the correct color for the Sensenich metal prop?
I checked the Sensenich web site but found no color info.
Noel
RV-6A N6NF
tip-up
flying
Old 08-25-2014, 07:47 PM
Mike H Mike H is offline
Are you referring to the Tempest grey colored prop paint? If so it will be a very close match. I have repainted several FP props with this paint and it works very well but you must let it fully cure.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 08-25-2014, 08:06 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Isn't it the same shade of gray as a Hartzell CS prop? I've seen a fairly new Sensenich FP metal prop parked near a new Hartzell CS prop and the colors were indistinguishable to me.
Neal Howard
Airplaneless once again...
Old 09-01-2014, 09:49 AM
Just wanted to finish up this post with info so I can find it in the future.
I talked to to folks at Sensenich and they sent me rattle cans for the flat black, white, and gray:
Gray is Tempo # A-151 Gray Hartzell, Aviall item #A151
White is Tempo # A-152 White, Aviall item #A152
Flat Black is Tempo # A-150 Flat Black, (Aviall number not listed)
Aircraft Spruce only carries the Gray, p/n 09-00983, and is the Tempo A-151 Hartzell Gray. Aircraft Spruce calls this "Tempo Med Gray Epoxy Prop Coat".
Noel
RV-6A N6NF
tip-up
flying
