Old 10-12-2006, 02:26 PM
dwilson dwilson is offline
Default Best way to finish joint between fiberglass empenage tips and aluminum skin?
What should I do to the joint between the fiberglass empenage tips and the adjacent aluminum skin
1) Nothing
2) Fill with something
fiberglass flox
body putty
3) Fill and then cover with a fine mesh fiberglass cloth
4) Other ideas????
Duane
Duane Wilson
RV9A. Built, flew 1000 hours, Sold
RV10 Built, flying 330 hours so far.
Central Oregon
Old 10-12-2006, 03:20 PM
az_gila's Avatar
az_gila az_gila is offline
Duane
1) will crack under the paint
2) will probably crack under your paint, like 1) but you had to do more work to get to the same state...
3) I went this way... need to scuff the alum. just like the metal under the windshield fibreglass....
4) Would like to hear. Some folks used ProSeal to attach the end pieces... would like to hear if this flexed and cracked under the paint...
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-12-2006, 03:27 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
I haven't done it yet, but this is what I plan on doing. Darwin Barrie, my fiberglass consigliere , sent me to CST for some really lightweight cloth/tape that is perfect for this purpose.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 10-12-2006, 03:29 PM
AndrewTR30 AndrewTR30 is offline
Default Do like Dan
http://www.rvproject.com/20031228.html
Vans says uneven expansion and contraction can cause the joint to crack if you only fill it in. I think the layer of cloth will prevent this.
Dan C. any comments?
Andrew Rayhill
RV-10 40078
Phoenix
Old 10-12-2006, 03:30 PM
pierre smith's Avatar
Default KISS
Hi,
#1. Pop rivet 'em on and paint them. If you use fiberglass, are you going to stretch it over the stab as well? You're asking for more weight/time/expense.
KISS, IMHO
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-12-2006, 03:44 PM
Capflyer's Avatar
Capflyer Capflyer is offline
I just finished putting most of mine on. After the poprivets pull them tight to the aluminum, the seam between them looks natural. I figure that if I wanted it all to look like one piece I would have built a composite plane.
The only issue I have is that the right HS tip needs to come out a little to match up with the elevator tip. This leaves the gap between the HS and the indented flange on the fiberglass tip with a gap that is about 1/8". I'll just use a little filler in there and when it cracks it will crack along the aluminum HS and match everything else.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 10-12-2006, 04:04 PM
painless painless is offline
Originally Posted by pierre smith
Hi,
KISS, IMHO
Amen Pierre. Its a metal airplane. You're 'sposeta see joints like that!
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 10-12-2006, 05:20 PM
dan's Avatar
dan dan is offline
1100 hours, and the only spot where the gap has made itself evident is where I sanded through the fiberglass.
Dan Checkoway RV-7
Old 10-12-2006, 06:29 PM
rvpilot's Avatar
rvpilot rvpilot is offline
Thumbs down Fiberglas? Why???
Yuk! Already to much fiberglas for me, do nothing! Looks good, will last a long time!
Bill Waters
Based KCVC (Covington, GA)
RV6A - Gone, but not forgotten!
RV8 - Gone too, now winning races in the RV Gold Class!
RV4 - Flying!!!
Old 10-12-2006, 06:52 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
If your joint looks nice and clean don't do any thing. Just leave as is. If it looks like 10 pounds of poo stuffed in a 5 pound sack, I would cover it.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
