There was a very long and thorough analysis done on this topic years ago and I don't want to rehash it again. What you see is a switch failure. The hot switch burnt the terminal wire.
I have had four separate switch failures all caused by loose switch rivets. As soon as the rivet corrodes or is stressed, it increases in resistance, leading to overheating.
Armchair quarterbacks may disagree, but the technical analysis was conclusive. Honeywell switches are fine.
Use the famous internet search engine to find "aeroelectric carling switch failure". Popcorn advisable.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
