Old 08-24-2014, 11:29 PM
N546RV's Avatar
N546RV N546RV is online now
Default Tank access cover doubler...bad idea to notch the edge?
Back story; I was working on the anti-hangup guides for my right tank today. I wasn't too fond of putting the inboard guide right across the middle of the access hole, so I decided to locate it further aft and attach it directly to the rib instead of through the doubler. After evaluating the travel of the weight at the end of the flop tube, I ended up positioning the guide such that it angled forward at the top of the tank.
Unfortunately, after drilling the holes in the rib, I realized that the top end of the guide was going to interfere with the doubler. After thinking through the problem, I convinced myself that the best option was to put a notch in the doubler to clear the end of the hangup guide. I didn't feel that this would compromise anything structurally.
But now that it's later and I'm not in the heat of the how-do-I-deal-with-this-stupid-thing-I-did moment, I'm questioning this decision. Which if of course why I'm posting here.
Here are photos of the setup and the notch:
Minimum edge distance between the screw hole and the notch is a hair under 1/8".
My analysis is that with proper smoothing of the notch, there isn't much of a chance of a crack developing here. Seems like a low-stress area. But now that I'm looking back at this, I feel like I need a sanity check.
Worst case, moving the thing wouldn't be much of a big deal. There'd be an extra hole in the rib, but that's easily plugged with a rivet and sealant. And I'd have to order a new doubler, which looks like a $10 part from Van's.
So...what say you?
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 08-25-2014, 12:09 AM
N546RV's Avatar
Actually, you know, I'm just going to order a new ring in the morning. I should know by now that if I'm asking "was this a stupid thing to do?" that the answer is most likely "YES." Besides, better to spend ten bucks now than to have one of those parts of the plane where I keep wondering if it's OK...
Philip
Old 08-25-2014, 01:27 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
In general, I find it's usually easier and better to add a shim rather than cutting away material.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-25-2014, 06:03 AM
Mike H Mike H is offline
That small of a notch will be just fine. Save your money and drive on.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 08-25-2014, 06:29 AM
wirejock's Avatar
wirejock wirejock is offline
Default Notch
Is there any reason why you wouldn't attach it at the ring rather than at the rib?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 08-25-2014, 07:06 AM
aeroaddict's Avatar
aeroaddict aeroaddict is offline
Just FYI; mine are both centered on the doubler and there is still room for me to insert my big fat hand.
Dan
RV-7 Slow Build - Sold
KEUL
Old 08-25-2014, 07:43 AM
aerhed aerhed is offline
Will the whole bunch get pro-sealed? If so, why worry?
Actual repeat offender.
