Old 08-24-2014, 10:14 AM
DragonflyAero DragonflyAero is offline
Default No holes in tail spring and tail spring mount?
When I ordrered the fuselage kit I deleted the tailwheel assembly, as I intend to go with a Flyboy. What I did not know at the time was that this assembly included the tail wheel spring and tailwheel spring mount, both of which I still need. So I ordered these parts separately from Van's (by the way, the 2 parts cost nearly as was discounted by deleting the whole assembly, so I wouldn't do that again). I received the parts this weekend and was surprised to see that neither the spring nor the mount were drilled for the holes where the spring is bolted to the mount or where the tailwheel is bolted to the spring. I expected to have to drill the mounting holes in the plates where the mount attaches to the bulkheads, but not these others.
Is this correct? I can find no mention of drilling the mount and spring. This is really sturdy steel (especially the spring) and I'm not sure I have the means to drill it. Can anyone help?
Bill Vinson
RV-7 Standard Build
http://www.mykitlog.com/users/index....r&project=2226
Old 08-24-2014, 10:31 AM
riseric's Avatar
riseric riseric is offline
Same for me Bill,
I deleted the tail wheel assembly then ordered from Vince the spring and everything behind.
I had to order later from Van's the mount.
Nothing is drilled of course...
So I'm putting it off for now and think about it.
Either I'll buy a very good drill guide to do the holes or go to a specialized shop...
Eric,
2020 dues paid
RV-8 83274
Emp & SB Wings on fuse, SB Fuselage in progress
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro & EFII Bus Manager & System 32 in progress
Aerosport IO-375 + MTV-9-B/183
Skyview HDX (next)
Old 08-24-2014, 11:05 AM
N941WR's Avatar
N941WR N941WR is offline
Call Van's and ask them for the name and number of the person who makes the sprint mount and spring.
Then call them and ask if they will drill the spring to the mount, if you send it back.
I suspect the reason they are not drilled, when bought separately is because they don't know if these parts are going in an older kit or not and if they are, then they need to be drilled to match those older planes.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-24-2014, 11:27 AM
So if received as part of the Assembly they are already drilled? If that is the case I may call Van's and see if I can return the mount and spring for credit and order the assembly at the "kit" price which they credited when I deleted it.
Bill Vinson
RV-7 Standard Build
Old 08-24-2014, 11:58 AM
AlphaCharlieBravo AlphaCharlieBravo is offline
What Bill said and yes when you receive them in the kit they are drilled except the three (3) holes into the bulkhead.
Arnie Barros
VAF #1401
(N89269) reserved
"Seek to understand before trying to be understood"
Old 08-25-2014, 10:25 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Bill R. is correct. There is no way to know on retrofit parts whether there are existing holes to be matched in other parts.
Drilling these holes isn't the same as drilling aluminum, but anyone can do it if they follow the right procedures. Nothing special is needed.
1) use only SHARP bits. A dull bit will turn but not cut properly, often with a loud screech, and cause the parts to work harden. Stop drilling immediately and get a sharp bit. You MUST keep the bit cutting at all times to avoid the screeching and overheating.
2) use cutting oil. Most any oil will work OK if you don't have cutting oil.
3) Use a slow turning drill and plenty of pressure.
4) always drill undersize and step up to the final size after everything is lined up and all undersize holes are drilled.
If you can do the drilling in a drill press or mill, it is easier, but you CAN do it by hand also.
It isn't as difficult as it sounds.
We also have tip sheet on our web site:
tailwheel maintenance and related tips
Drilling tips
In a pinch, any machine shop can do the job quickly. However, consider alignment issues before drilling anything away from the plane. It's not good to have a crooked (not plumb) tailwheel !
For additional questions, email me or call my office. vincefrazier@gmail.com or 812-464-1839
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 08-25-2014, 10:09 PM
akarmy's Avatar
akarmy akarmy is offline
Good tips Vince. I had the same issue when I ordered the parts. They were easy to drill with my $200 drill press and new bits!
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
Old 08-26-2014, 02:57 AM
riseric's Avatar
Thanks Vince and Andy for your tips and reassuring words !!!
In time, I will surely use those tips and my drill press and share the results here.
Eric,
2020 dues paid
RV-8 83274
Skyview HDX (next)
Old 08-27-2014, 05:09 PM
I decided to use a machine shop to drill the bolt hole through the mount and spring, and will take the spring back to them to drill the tailwheel to the spring. It cost a few bucks but they were dead-perfect in the drill so I am pleased.
Bill Vinson
RV-7 Standard Build
Old 08-28-2014, 01:49 PM
vfrazier's Avatar
Bill,
Just make sure that you have identified some way to make certain that the tailwheel will be plumb once you put it back on the plane.
One way to do this, and it's tiny bit of work, but not bad is to install a small set screw into the mounting socket housing. Use the set screw to hold the mounting socket to the tailspring when you set the tailwheel up to be plumb.
You can put the set screw where one of the mounting bolts will go, if it's undersize. Or just pick a suitable, out of the way spot for it. The top front edge of the mounting socket is probably as good as any.
Then pull the parts back off the plane and take them to the machine shop for drilling. Assuming nothing moves, you should have a perfect outcome.
There are other ways, clamps, pins, drill one bolt hole undersize and leave a drill bit in it, etc... lot's of ways to skin a cat.
I've used the set screw technique on gear leg sockets and elsewhere with success too.
Vince Frazier
www.f1aircraft.com
