Countersinks
Welcome Steve.
Sometimes they do look deep. Wait till you countersink your expensive spar flange for #8 tank dimples. They look huge. Just use a sample token of the correct thickness and dimple as a gauge.
I made a set of tokens. Each is a piece of sheet aluminum about 1"×2". I cut one of each .025 and .032 for each size dimple die. 3/32" standard, tank, substructure, 1/8", #6, #8. That's 12 tokens. Each has a hole of the correct size and a dimple. Each is labeled with a scribe. I use whichever is needed to make sure the countersink is the right depth in scrap first then the actual part.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Reason: edit
