08-23-2014, 01:24 PM
Fuel Tank question: what kind of loctite
I am at the point where I need to install the threaded parts in the fuel tank like the drain valve.
Which material do I use for the threads on this item? I know I want lactate, but which type.
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
08-23-2014, 01:30 PM
I think the tanks are lactate intolerant (I couldn't resist). There is a white loctite, but I don't remember the number. I always use Seal Lube for pipe threads.
Jesse Saint
08-23-2014, 01:33 PM
Fuel lube
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
08-23-2014, 01:35 PM
Permatex #2 sealant
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
08-23-2014, 03:07 PM
Moderator, Asst. Line Boy
I hate autocorrect. It always changes my typing, and I can never say what I Nintendo.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
08-23-2014, 03:23 PM
Loctite 567
Use on all tapered threads... Great stuff!!
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
08-23-2014, 05:08 PM
567 is good, I like Titeseal and Bakerseal for pipe threads as well.
"Fuel Lube" is not recomended for pipe threads.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
08-24-2014, 08:48 AM
What!
It's recommended by me and the manufacturer! I've used it for 9 years on my fuel drains and they have never leaked. This is what it is made for, read the description.
EZ Turn is a specialty lubricant/sealant used for fuel and oil line valves & is resistant to high temps. Especially effective where high octane fuels and aromatics are present. EZ Turn is also extremely efficient as a gasket paste & anti- seize agent. EZ Turn will not gum, crack or dry out. Each shipment is independently tested. Excellent for tapered plug valves, aircraft engine manufacturing, and marine applications. EZ Turn is the functional equivalent of fuel lube. 1 Lb. can
08-24-2014, 12:34 PM
Originally Posted by bhester
What!
Where does it say tapered pipe threads?
08-25-2014, 11:59 AM
and proseal?
What if a small dab of regular ProSeal is used for such fittings?
I have gone before myself and placed a small amount of proseal on the fuel drain before realizing it.
I'm wondering if it is suitable for other fittings such as Flop Tube, and vent line?
Should I remove and clean the fuel drain?
thanks
Miguel Vidal
EAA #1133587
RV-8 SB Wings in Monterrey, Mexico
N511MV Registered
MyKitLog
