Old 08-22-2014, 07:07 PM
hlangebro's Avatar
hlangebro hlangebro is offline
Default More high CHT's etc. Some test results
So, I have had high CHT's in climb since day 1 (410-425f). I was pondering about the fuel nozzle and wanted to check my egt's, fuel flow etc. So here are my test data from today. Cht's corrected for 100F day.
Engine is a O-320 D3G, 160hp, Whirlwind GA200, RV7A. Cowl flap.
On ground 1200rpm -60rpm increase from full rich to just before rough. Just about right.
Static; 2160rpm, 130hp, 81%, 12.8gal/hr. A little low for fuel flow...
Climb, cowl flap full open, full rich, 115kias:
cht: #1 393, #2 408, #3 391, #4 379
137hp, 85%, fuel flow 12.3gal/hr. Fuel flow seems low....
Cruise, 8500ft DA, WOT, full rich, cowl flap closed, no increase in rpm during leaning, 2730RPM, 77%, 124hp, fuel flow 13.2gal/hr
EGT's (from full rich to peak, delta F):
#1 88F, #2 96F, #3 127F, #4 151F
CHT (as indicated)
#1 352 #2 365 #3 354 #4 361
Conclusions....
Seems like it is running a bit lean, but not by much. I would say that an increase in fuel flow would definitely keep the cylinders cooler and I could potentially climb at a lower speed without hitting 400F. I'd like to stay below 380F.
I am pondering about re-jetting. One thing that I also need to double check is that the mixture lever actually opens fully. I have the James cowl with pressure plenum. I have sealed everything and checked for induction leaks, I have been modifying for about a year now, with some success, but I still haven't found the smoking gun... my guess is that the mixture is a bit too lean...
H?kan Langebro
San Diego, CA
RV-7A, slider
Lycoming O-320 D1A, 160hp C/S
First flight 6-11-13
Re-engineering a Lancair 320..!
http://www.youtube.com/watch?v=AJuQ68tccTQ
http://www.mykitlog.com/hlangebro/
Old 08-22-2014, 07:35 PM
erikpmort's Avatar
erikpmort erikpmort is offline
i almost did the jet drill. I had the carb off, ready to drill, and i was told not to by a guy on this forum and i also found more reading that said it isn't a good idea. But you know what? kinda thinking i should have. it has worked for others. Let us know your results if you do it. I started going full rich at take off instead of leaning to peak and then two turns rich- it helped a little but not sure. Again I was told to try to achieve 1250 egt and i can't get it that low.. my temps are pretty similar to yours except i have louvers not a cowl flap... cooler weather is almost here and i'm exhausted from fighting this problem this year. i've made good improvements but still not satisfied. good luck
Erik Mortenson
Rans S-20 low and slow
14 build working on wings
Old 08-22-2014, 07:38 PM
DanBaier's Avatar
DanBaier DanBaier is offline
I think that if, when you lean the mixture, you can get a 100 degree rise in EGT, you are not likely to be running too lean and I don't think I'd be inclined to re-jet. Also, the ground test at 1200 is likely still on the idle circuit and is probably not going to reveal much in terms of the jetting.
I think I'd look at #2 & #4 with an eye toward balancing the temps on climb - if you could get #2 down a little and #4 up (adjusting the dam at the front of #2), then the spread would be more uniform and the numbers don't look to be bad at all. You'd be at or just below 400 all the way around on a WOT climb.
I think if I could get the balance of those cylinders I'd declare victory.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 08-22-2014, 07:47 PM
<snip>
<snip>
CHT (as indicated)
<snip>
Your temperatures look fine to me. There is nothing wrong with cooler temperatures, but there is nothing wrong with where you are today.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-22-2014, 08:05 PM
hlangebro's Avatar
Default Temps and speeds
I would like to be able to climb better, around 100kias, but there is no way I can do that without, in my opinion, running to hot on Cht's...
I've been trying to balance the temps, but some reason the left bank runs hotter...
H?kan Langebro
San Diego, CA
RV-7A, slider
Old 08-22-2014, 09:26 PM
ColoRv's Avatar
ColoRv ColoRv is offline
Have you run the high MP, low MP test to assure you have no intake leaks?
Click Here
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 08-23-2014, 08:20 AM
Toobuilder's Avatar
....Climb, cowl flap full open, full rich, 115kias:
CHT (as indicated)
... I have sealed everything and checked for induction leaks, I have been modifying for about a year now, with some success, but I still haven't found the smoking gun... my guess is that the mixture is a bit too lean...
Funny - I'm working cooling issues as well, but what you consider a "problem" is my "goal". Barely above 400 in the climb and mid 300's in cruise is the promised land for me... I don't think you have a problem at all. I'm not saying you should stop looking at the details- air cooled engines need a lot more attention to detail for localized airflow management, but as a gross figure you're in great shape.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-24-2014, 01:47 PM
hlangebro's Avatar
Default More data...
Did another test today. I heard from Sam James that wrapping the inlet tubes with exhaust wrapping would cool the inlet air and thus lower CHT's. Don't think it did anything...
This time I climbed out at 110kias, so 5 kias slower than before. Temps compensated for a 100F day:
#1 403, #2 411, #3 399, #4 385
Ok I guess, but not great.
I also did the induction test. EGT deltas:
#1 38, #2 44, #3 50, #4 111
What does this really tell me? cyl 1-3 are reasonably close, but #4 is way more... Seems like 1-3 are running lean and #4 is rich...? Would this mean I have induction leaks on 1-3?
H?kan Langebro
San Diego, CA
RV-7A, slider
Old 08-24-2014, 02:38 PM
ColoRv's Avatar
You can't diagnose induction leaks by doing a climb test versus temps. Run the test I linked earlier.
Also, what does 'Temps compensated for a 100F day' mean? Are you saying the temps listed are not your actual temps? 100F at what altitude?
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 08-24-2014, 03:22 PM
hlangebro's Avatar
Let me clarify.
Climb temps are compensated by the OAT and 100f delta, as it should be done. So, actual temps were lower since it was not a 100F day. The temps stabilize fairly quickly, so I would say about 1500ft or so. You should always normalize the cht temps to 100F.
As far as the induction leak test. I was a 8500ft DA and noted the full rich EGT, WOT. I then pulled back 10" and noted the EGT temps. Deltas as shown.
H?kan Langebro
San Diego, CA
RV-7A, slider
