Old 08-21-2014, 11:29 AM
William William is online now
Default Help me identify this Lycoming cylinder....
Hi all I've pulled my cylinders to install new 9:1 pistons and rings. Only problem is the logbook was missing when I purchased this engine. I've already overhauled the lower end but figured I would freshen the cylinders now. I've already did a valve job to the cylinders and now it's time to hone and add the new pistons and rings. Now to the problem, my cylinder has both a blue strip and a orange stripe. Can someone identify this cylinder as chrome or nitride so I can be sure to purchase the proper rings. The cylinders are standard size and measure fine with the dial bore gauge.
Bill
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 08-21-2014, 12:10 PM
az_gila's Avatar
az_gila az_gila is offline
Question
This is from ECI -
Lycoming or ECi replacement Cylinders for Lycoming Engines: Color Codes for the outer fin tip area between spark plug and cylinder barrel or color band between the flange and lower cooling fin are:
Standard Size Barrels:
? Engine Gray or Unpainted - Plain Steel or thru-hardened Airmotive Steel
? International Orange - Chromium type bores
? Two (2) Silver Stripes - CermiNil Process and/or Nickel+Carbide Bores
? Blue - Nitride Hardened Steel
Oversize Barrels:
? Green - Plus .010 Inch
? Yellow - Plus .020 Inch
Color codes for fin area between spark plug and rocker box are
? Engine Gray, Blue or Unpainted - Short Reach Spark Plugs
? Yellow - Long Reach Spark Plugs
Could it be that the blue is just overspray from somewhere since it's location is incorrect?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-21-2014, 12:47 PM
Originally Posted by az_gila View Post
This is from ECI -
• Engine Gray or Unpainted - Plain Steel or thru-hardened Airmotive Steel
• International Orange - Chromium type bores
• Two (2) Silver Stripes - CermiNil Process and/or Nickel+Carbide Bores
• Blue - Nitride Hardened Steel
Oversize Barrels:
• Green - Plus .010 Inch
• Yellow - Plus .020 Inch
• Engine Gray, Blue or Unpainted - Short Reach Spark Plugs
• Yellow - Long Reach Spark Plugs
Hi Gil
Thanks for the response. It could be except all 4 of the cylinders have the blue and orange stripe in the same place.
Bill
Finishing a RV10
Old 08-21-2014, 12:57 PM
Mel's Avatar
Mel Mel is offline
The "blue" I've seen has always been on the fins where your orange is.
My guess, and it is just that, is that the cylinders were originally nitride and have since been chromed.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-21-2014, 01:14 PM
This is my guess as well. I know that nitride cylinders use a chrome top compression ring and chrome cylinders use plain steel rings. Let me take a picture of the top compression ring and see if this can help with the identity of the cylinder plating material.
Bill
Finishing a RV10
Old 08-21-2014, 01:26 PM
rocketbob's Avatar
Well the stripe is orange and the bore looks chrome to me. A cast iron ring will shatter if you smack it with a hammer. Removed of course
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 08-21-2014, 02:25 PM
Here are a picture of the rings. I put the ring on the steel shoulder of my work bench vise. Gave the ring a hard hit with the hammer and the ring only broke in 2 pieces. Is this what would be expected from cast iron rings?
Bill
Finishing a RV10
Old 08-21-2014, 03:23 PM
rocketbob's Avatar
Correct. Those are cast iron rings. They appear very worn.
N8155F C150 flying
Old 08-21-2014, 03:35 PM
Awesome Bob thanks for your help! Thanks Everyone else for your help as well! Vansairforce family comes through again!
Bill
Finishing a RV10
Old 08-21-2014, 04:23 PM
Doug's Avatar
Doug Doug is offline
I have no expertise with engines but - the base flange seems thin. Is this correct for a 9:1 CR engine?
Doug Gray
RV-6 completed, flying since July 2010
