Bleeding Brakes Again...
During my inspection the inspector noted that there was an air bubble in my brake line. So I'm bleeding them again.
I'm using the push up from the bottom method. I have dual brakes. It works great until it gets to the passenger side master cylinders. On both the right and left pedal there is about a 1 inch air bubble that I can't push through the master brake cylinder.
Fluid is still coming out the reservoir, so I know that brake fluid is going through the entire line.
Did anyone else struggle with this?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
