Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 08-20-2014, 11:23 PM
cbennet1 cbennet1 is offline
Default Left or right mag?
To those that installed a single EI, did you replace the left or right mag?
What was your reasoning and did it work out as planned?
My understanding is that with the EI working, you'll still start on the EI. But in the event of an EI failure, having the impulse coupled MAG would be beneficial. On the flip side, ditching the left mag reduces moving parts/complexity.
Thanks in advance,
Craig
Craig Bennett
321GT Flying RV6
2018 dues paid, how about you?
Old 08-20-2014, 11:56 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
My personal opinion is stick with two mags.
So with that out of the way. Why would it matter if you had a EI failure??..surely you are not about to start up and fly away on the one remaining mag?
I think it is possibly a moot point.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 08-21-2014, 05:15 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Personally Id keep the impulse mag. If your having EI problems, it is advantageous to be able to get the engine running for troubleshooting.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 08-21-2014, 06:37 AM
Toobuilder's Avatar
And just to show the other side:
I dumped the complexity, weight, and possibility of trashing the accessory drivetrain of the impulse mag. Couldn't wait to get that hand grenade off my engine.
If I was flying a Supercub into the Alaskan bush, I might think differently.
It really doesn't matter. Consider the benefits and pitfalls, but don't agonize over the decision.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-21-2014, 06:38 AM
RVDan RVDan is offline
I kept the impulse (left) mag. If the battery is really low and just able to get over compression, the EI probably won't work. Learned this lesson in the past where I replaced the left mag and had no impulse on right.
I am considering the possibility that I am away from home and need to get the engine started.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 08-21-2014, 07:29 AM
aerhed aerhed is offline
Actually, I've been wrenching planes over 30 years and have never seen a coupling come apart, have never heard about it on an airport I've worked at, and don't know anyone personally that 's had one come apart. Its just not real common now that people actually look at them occasionally.
Actual repeat offender.
Old 08-21-2014, 07:38 AM
Kahuna's Avatar
And to piggy back on what Dan said.. A dead battery and a hand prop has gotten many a pilot by with an impulse mag.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 08-21-2014, 09:03 AM
Bavafa Bavafa is offline
Same thing here for the same logic.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 08-21-2014, 09:31 AM
N941WR's Avatar
N941WR N941WR is offline
And the right ignition is usually easier to remove and replace.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-21-2014, 03:32 PM
eddieseve eddieseve is offline
Just a comment on flat batteries and P-Mags.
I have dual P-Mags, left the master on for 1 week so the battery would turn the prop but could not get it past the compression stroke.
A friend hand propped for me, and the engine fired on the second pull through.
So from my perspective these things are great and you can still get out of trouble in most situations.
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
