Neat Ideas. Initially I bought cheap magnetic white boards to attach plans and write notes around the sides. I also fitted 2-3 plans on top of each other, with the magnets on top to lift the plans. That worked well during the initial portion of the build.
Deeper into the build I found I am going backwards and forwards between the plans, so I just photocopied the preview plans. I compared them to the Big plans to note updated areas, and marked that areas with a RED pen.
I stapled the preview plans in 3 sets +/- 10-15 pages in a set in the corner. Now I have them all easily avialble, easy to flip them over. If I need something full scale. I just pull out the big plan for that area.
I find that since doing my photocopy sets of the preview plans I use them more often, than the big plans.
Regards
Rudi
Here is a view of my white boards with some plans in the background, ignore the pane..
