Flox usage
I'd echo the comment about Van's aircraft and composites. Mostly fairings and wheel pants here...
But flox has no place in adding strength to a layup like you describe. It can be used to make hard points, create hard edges where an inside or outside corner is created, or to secure an embedded fastener or the like. But no, adding flox to resin in a molded layup like you describe will only lead to added weight, not added strength.
Kevin R. Walsh
Cozy Mk-IV
