Help, I'm stumped!
Background. 2004 RV-8. I purchased in early Feb this year with approx 800 SNEW. Superior XP-360 with Bendix RSA-5 injection system. Engine now has approx 1,000 hours. No purge valve. Engine originally had 2 Slick mags, about 300 hours each, with Tempest massive electrode plugs. I replaced one mag with an EFII EI system, I have also replaced the Holley fuel injection pump with an EFII boot pump module. Compressions at pre-purchase all high 70's. No significant issues with oil analysis performed every change since new including one I just did a month or so ago. I'm running 100LL.
Problem. When engine is hot, I get a VERY lopey, rough idle. It will idle for a second or two at 1,000 or wherever I set it, then the idle will drop out down 800 or lower for a second, then back up to 1,000. It feels like a cylinder is dropping out for a second then coming back online, but I see no indication in the EGT/CHT to identify if this is in fact the case or identify which cylinder. Problem seems to be worse the hotter the engine is. When its hot I get a lot of sputtering, occasional backfire, and sometimes feels like its almost about to quit.
The airplane did not do this when I picked it up, it has gradually gotten worse as the year has progressed (and the WX has gotten warmer?). Problem did NOT suddenly start with either the pump or the EI upgrades.
The engine does make good power and performs well in the air.
What I have done:
-2 new sets of automotive plugs - no difference
-cleaned gaped ohmed out all aviation plugs (900-1k ohms) no difference
-mag is dead nuts on 25 BTDC
-all ignition leads are in ex cond.
-problem does not change when running on mag, EI, or both anyway
-problem does not change when fuel pump on or off (pump works properly)
-problem doesn't change with different mixtures on the ground
-for a few seconds after a cold start runs rough them smooths out, but.....
-checked all exhaust valves and all valve springs, no broken springs, all valves smooth as silk, no sticking, and just the tiniest bit of wobble (no dial gauge but seems fine)
-all new intake gaskets and hoses/clamps - no change
I'm stumped. I'm going to try the "clear tube" test and see if I'm somehow getting air in the fuel lines, clean all my fuel filters and strainers, and double check all the adjustments on the fuel servo this weekend.
Any guesses?
Here's a short video showing the behavior. I'm not touching the throttle.
