Old 08-18-2014, 08:12 PM
Toobuilder's Avatar
Yep, torque seal is only good until the first flight, or it dries, whichever occurs first. It's used as an indicator for a snapshot in time, that's it.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-19-2014, 07:32 AM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
Thank you fellas, lots of good stuff in this thread for new-bees like me.
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 08-20-2014, 05:01 AM
novipilot novipilot is offline
All good info. One more thing I didn't see in any of the threads. The smooth appearing metal in a joint build-up may look smooth to the naked eye. But look at it through a high powered microscope, and it looks like the view crossing the Rockies. It's the tops of all those peaks that get worn down or permanently compressed during operation, and that relaxes the stretch of the bolt thus loosening the joint.
And remember, torque is just an approximation of bolt stretch. Take 100 "identical joints", strain gage 100 bolts (only done in a lab), torque them all to identical values, and you will have 100 different measures of bolt stretch (strain). We did this often in the auto lab where I once worked.
Rich Bond
Just a wishful observer
Gave up awaiting AOPA/EAA exemption request
2015 =VAF= Contributor
Old 08-20-2014, 06:35 AM
rgmwa rgmwa is offline
In structures we don't use torque wrenches - too many variables. Part-turn-of-nut is the preferred method as it's more reliable, or using special load-indicator washers that have known deformation characteristics.
rgmwa
RV-12LR 912ULS
120346
Old 08-23-2014, 07:44 AM
WingedFrog's Avatar
Here is a follow-up question as I am now actively checking the torques of my engine mount:
The 4 Rotax bolts that I need to check are not easily accessible but one is particularly challenging: the top right side one which hides behind the right carburator. It looks like I will have to remove the carb to acces it. Any advice from those who have been through this? Note that I have the modified shroud "easing" the access to the two upper bolts.
Sport Pilot
Kit # 120395 N124BX
EAA 1114
Old 08-24-2014, 10:55 PM
RFSchaller RFSchaller is offline
Check the thread you posted on this for a description on moving the intake manifold. Quick and easy.
