Go Back   VAF Forums > Main > Reviews
  #11
Old 06-28-2019, 12:44 PM
Brantel's Avatar
Brantel Brantel is offline
Brantle,
Curious if you know the sevo?s recommended operating temp specs on the EZ-Cool flap? Also how many hours and if any servo failures?
Andy
Way back when these were released, someone found the OEM specs on the servos and the recommended operating temp was fairly low for the environment that they are to be used in. That being said, when I first installed mine I wrapped them in reflective aluminum tape and have had no failures of the servo to date. I installed them 5 years and several hundred hours ago.
The only failure I have had is the hinge. Allan sent me new units with a reinforced aluminum hinge. I wish I had the units with the new stainless hinge.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 06-28-2019, 02:06 PM
PerfTech's Avatar
PerfTech PerfTech is offline
?. The rated temperature was lower than I would have liked and as time passed
I became more concerned that we would begin to see failures related to temperature.
When our volume became such that we could justify buying direct we contacted
the manufacturer China and purchased direct. I quizzed them about my temperature
concerns and they said the most sensitive thing was a glue they use in the assembly.
They said far a sleight increase in price they can use a higher temp glue. We
agreed and they switched over long ago on our orders. In all fairness we never
experienced any failures with the other glue, so perhaps my efforts were a waste
of time. Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 06-28-2019, 03:30 PM
Barbeau's Avatar
Barbeau Barbeau is offline
Hi Allan
I?m a friend of Sylvain and I fly a RV6A, O360 with Lasar ignition and 3 blades CS MT propeller.
I?m working on sub cowl based on Larry Wetterman tests.
The main objectives are reducing cooling system drag at high cruise speed and reducing CHT when climbing.
Do you know anybody who did such sub cowl with one EzCool flap or lover on it AND EzCool flap under main sub coal Or to you have any experience on such fitting.
Bernard
France
LFBN - Niort Marais Poitevin
RV6A - F-PGAK - o360 A1A - AFS 3500 - Flymap - Garmin avionics
2009 - 560 hours
Old 06-28-2019, 04:19 PM
PerfTech's Avatar
Originally Posted by Barbeau View Post
Hi Allan
?. Sorry but I have very little experience with that system or mods. The absolute
guru when it comes to this subject would most assuredly be Dan Horton.
I can't think of anyone that has done more or better testing than Dan. Do a
search for his threads on exit air Etc. They are excellent and very informative. Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
Old 06-29-2019, 07:57 AM
Barbeau's Avatar
Thanks a lot Allan, I?m going to look for more details through VAF forum.
Your Ezcool flat should meet my project needs.
Bernard
France
2009 - 560 hours
Old 07-03-2019, 06:25 AM
crabandy crabandy is offline
Thanks for the Pirep!
RV 7 400 hours and counting
19 donation done
